Question P0404 Egr
bigdadie
Loudon,NH
OK my truck set off p0404 right after a hard pull, rest the light came right back after a hard pull, but if i drive normal it will not turn on the light, I pulled the egr, was not that bad But I want to say its only 99 present closed as it sits out of the truck cleaned, is this right?
my truck is a 04
Not being 100% closed is what caused the fault. Clean it real good with a small brass wire brush to get off all the carbon build-up and you should be good. There is no 99% with these computers. It is, or it is NOT. No in-between.
Dave :)
trailey97
DELETE IT!!! lol oh wait you are in hampshire, you probably cant get away with that huh?
bigdadie
Loudon,NH
Yes We can any Get away with removal of the egr up here, any Trucks 8600lbs and up are exempt from emissions testing
trailey97
lucky for you eh???? lol i say delete it then...cheaper in the long run and easier on you.
Svttim
