Question P1210 code What`s causes it, what make it go away.
xtrahappy
florence, mississippi
This code "P1210" On a 2000 F350, 7.3, 6 speed, 219000 miles. What causes it and how do I make it go away? Also had P0340 code, got CPS coming to fix that I hope.
I`d like to thank all of yall, cause yall helped so much. You just don`t know, how much.
P1210 is Injection Control Pressure above normal. I am not any 7.3 expert, but I would guess you need a new ICP regulator.
What Dave said But.. Replace the CPS first.. then dis-connect the batterys (both) for 30 minutes to erace any KAM codes, and scan it again. If the ICPR comes up again.. replace the ICPR. From there.. @ 219,000 miles.. it may lead to a HPOP issue. (?)
If the HPOP is leaking any at all.. it could be loosing enough pressure to cause ICP issues.
jarrburg
