Question p1316
mr ney
mexico
hello good afternoon I'm new to the forum. greetings to all. someone knows how to delet the code p1316 on a 7.3 1999, the scanner tells me it's the injector 8 but already changed and was the same, and change the harness under the valve cover and it was the same, I put good ground to idm and was the same. someone knows what else can I do?
in advance tanks.
scanner should be able to clear it..
what year truck is it and what is it doing?
mr ney
mexico
has a minor glitch when at idle and is 1999 with 210000 miles, i have a edge evolution programer I clean the code but it comes again
you have other codes as well..
P1316 is telling you there are injector and IDM codes present.
mr ney
mexico
yes, with the scanner tells me it's the injector 8 but already changed and it was the same
OK... here's the rub..
if the code never got cleared, it's not going to clear itself.
if the code DID get cleared and came back, the injector wasn't the problem.
