POS elect window
XTrmXJ
NACHHOOOOOOO!!!!
Hampton Va
My rear passenger window wont roll up (electric windows) all the other ones work fine, That one has always been touchy and sluggish
XTrmXJ
NACHHOOOOOOO!!!!
Hampton Va
Nope its not the motor, At first everything lead to it until I decided to use a jumper to finish troubleshooting, The motor is fine, that door switch is fine (swapped with another door and same) Come to find out its the drivers door switch panel causing it
94f450sd
certified nutjob
plymouth,ma
check the wireing in the door jam.they are known to break wires in the door jams,especially on the drivers front door as it the most used door.
XTrmXJ
NACHHOOOOOOO!!!!
Hampton Va
I used the multi meter and ran through all the wire and I was getting constant power so I know its not the wiring, but I will look into it
happeetxn
9/11 Never Forget
Dallas
Xtrm,
I had the same problem in my 95 CC rear passenger door. There are these little plastic gears that get chewed up and have to be replaced. They are less than 7.00 at the auto parts store. You have drill a couple of holes to get the job done. I took picttures as I did it. If you replace them PM and I can give you a more detailed account.
Craig
