Power inverter to run a window unit :). ?
bears4x4
grease monkey
katy texas
I know it sounds crazy but I have a i believe a 800O btu 115v 15 amp window unit and was wondering what size power inverter I would need to run this in my work van:) to fix the Ac it's around 700 and I have a window unit :)
iracemine
black and tan
Cheese Curtain
not to sure. Would like to find out tho. I just bought a xandrex inverter and every one I was talking to said that the start up on AC units would kill any inverters. So.... I put in another window. Next year I will hard wire shore power to a AC unit, but would like to know if yours works!
To find the power requirement of your AC unit; amps X volts = watts, so 15 X 115 = 1725 watts. That is the running power required. The starting can be a lot higher, like 2200 watts to be safe. If you get a big enough inverter it will work, but it will kill a smaller inverter.
....And not to mention the 12v Battery (and Alternator) capability it would take for 2200 watt Starts, and then to Carry.. a 1725 Watt load, for any length of time ?
I'm think'n GENERATOR. (could be used for other needs too?)
:dunno
And if used In Motion.... WOW :dunno
....Not to mention the Battery capability it would take for 2200 watt Starts, and then to Carry.. a 1725 watt load, for any length of time ?
I'm think'n GENERATOR. (could be used for other needs too ?)
:dunno
I was thinking the samething. My bother was using a inverter on his van and was roasting batteries left and right just powering computer for his work. I got a Champion 3500 Watt Generator for my 5ther and it's great, it quiet and it powers the A/C and everything inside too. It about 400 bucks.
bears4x4
grease monkey
katy texas
Ok ok , next thought then, I have my work generator, 5500w running , now will that over heat in the van, and yes I would run the exhaust out side some how.
I hate to keep shoot'n holes in yer thoughts BUT.. Engine Heat, Oxygen depletion and Noise.. would need to be considered ?
bears4x4
grease monkey
katy texas
Every thing minus evaporater and hoses, I'm just trying tO be cheap as possible because I'm trying to save for the diesel repairs listed in my sig, rebuilding 7.3 excetra
