Power Seats
ddan2
Richmond VA
I have an 04 Excursion, The power seats are dead, I checked all the fuses swapped relays around. cant seem to find the the problem why they dont work? Yes it has the seat memory and adjustable pedles they dont work either. any suggestions? :dunno
Frankenstien
Frankestien
South Prairie Wa.
The seats motors are isolated from the frame, hens so is the ground. You should check the wiring off of the connector, On my truck I have a ground strap that bolts to the bottom of the seat frame. Its possible that it may have been kicked off or perhaps a corrosion issue.
