Power Steering Box
Elk
Colorado
I don't post here much, but I have a question.
The connection(s) to my power steering box are leaking. Does anyone have any advice on how to get to them? I'm hoping one is just loose, but I can't get a wrench on them.
Zmann ARGH
AZ
yup and wedge something in there to hold the liner up,, then some long open end or better yet line wrenches to tighten ,, it will be easy to inspect for the leak alo from this area
Elk
Colorado
Thanks guys. I was hoping for something quicker, but I do have a day off coming up.
Zmann ARGH
AZ
20 minutes tops
but thats only if it's loose and needs tightened
I almost doubt it .. but lets hope it's that simple
NJKen
Is a proud new daddy
central NJ
Somebody has to get that lucky eventually! Usually the hose is gone when they start leaking.
Ken
superdub01
SDD USMC/Wyotech
jacksonville nc
there is a nylon washer on some fittings, and a rubber O-ring on others. depends on your pressure and return lines. all lines will still rotate even when the fitting is tight, so dont confuse that with a loose line. they are engineered that way to compensate for body flex and vibration. your best bet is to remove the intercooler tube, put a drain pan down, and take both fittings out. you can get the nylon fittings or O-rings at any parts store very cheap. if the fittings themselves (not sealing washers) seem worn out, just replace the whole line. i paid $35 for a pressure line. also gives a good reason to flush the system since you have it apart. also very easy. just have to jack it up and cut the wheels left to right similar to bleeding brakes. if you have questions, i'll give more details.
