Help Needed Power Windows
scoutman77
iowa
try putting the passenger side down with the passenger side switch, then try to put it up with the drivers side switch, mine if you put it down, then try to put it up it wont go, if you don't try to put it up with the passenger side switch, but the drivers side, it will go up. don't know if that makes sense but .... basically don't try to put it up with the passenger side, just the drivers side. but make sure the passenger side was used to put it down.
The master switch is bad. I just dont have the extra $185.00 right now.
scoutman77
iowa
mine too, I use small wires to jump the connector to put the drivers side up and down.
