PreFuel filter fuel filter
oi8228oi
another 99
i was wondering has anyone added a filter inline so that the fuel filters on the motor dont have to be changed as often, cause at 30 bux for a filter :eek: :eek: :eek: i dont wanna replace it every 3k to 5k!!! if i upgrade my fuel system with a kit will it come with a inline filter?? also any recomendations for a good filter to use?
Djracer
Car Stereo Dude
Wetumpka, Alabama
I just got a filter to put prepump but I haven't installed it yet would love to do intank mods at the same time!
roosterdiesel
Earl needs B100
Amarillo,TX
I used a Racor 900FH Turbine series, heated at a 2 micron rating before the pump. Stock is a 10 micron if IIRC. 900FH filters are only $11.30. A little over kill, the 500FH would be a little easier to install for ground clearance issues.
Tbar
SDD STAFF/Moderator
Currently running the Racor 445R90. Pic was taken with the R60 element.
Tbar
Tail_Gunner
CRJ & ERJ A&P Mech.
Da U.P.
I installed a Wix/NAPA/Car Quest filter upstream of the fuel pump.
I put it ahead of the fuel pump to protect that expensive fuel pump from debris in the tank. It also helps prolong the life of the stock filter.
This particular filter is also a water separator and I have notice improved running last winter since it was installed.
vbpicgallery.php
I installed a Dahl 100, pre fuel pump. as you can see from the above Post, there are several to choose from.
joe
Fire1
Certified Diesel Driver
I also have a Dahl 100 w/ a 2 micron element in it pre-pump. I just changed it for the first time since install 8 mos. ago and my truck now runs quiet again. Also, check e-bay for the factory elements. I paid $26 plus tax/shipping for FOUR filters just last week.
