Problem ..Please Help.
ForumBlue
CDXX
Southern California
I was shimming my Fuel Pressure Regulator, and broke one of the torx head studs that holds the FPR cover on. Does anyone know where I can get another stud to replace it?
What is involved in taking off the filter bowl so I can get the broken piece out?
Or, is there a way to get it out without taking it off?
Thanks.
Jamie
kwazyca
Sesquipedalian
Redding, CA
You can probably get a replacement stud at a fastener place (nuts and bolts store). I am pretty sure it is metric. Take the broke off piece with you and have them use that to find you the right thread pitch and length.
Do you have an easy out set?
Tom
ForumBlue
CDXX
Southern California
I dont have an easy out set but I was thinking this might be the time to invest in one. My biggest problem is I have a feeling getting that fuel bowl off is not going to be fun. It looks like everything is hooked to it, and I cant figure out if it mounts thru the HPOP. If anyone has a "how-to" on how to get it out I would appreciate it.
thanks
Jamie
kwazyca
Sesquipedalian
Redding, CA
Depending on how bad you reefed on it when it broke, you might try left handed drill bits too.
Sometimes that does the trick.
Tom
kwazyca
Sesquipedalian
Redding, CA
Here is a picture of a fuel bowl out of the truck (scroll to bottom). Don't know if this helps you or not.
Poke here
Tom
ForumBlue
CDXX
Southern California
Are those bolts isolated or is oil going to come out? If anyone knows how to do this without creating a hugh mess , please let me know.
Thanks.
ForumBlue
CDXX
Southern California
BTW, I checked with Ford, and of course they wont just sell the bolts. You have to buy a kit with the cover and bolts. $39.24 mistake, but I guess I get a new o ring out of it not that there was anything wrong with the old one.
Bummer, you couldnt find a bolt somewhere else?
ForumBlue
CDXX
Southern California
I probably could but I need to get it fixed tonight. Thats why I'm hoping someone who has removed the filter bowl can help me out.
minerwelder
