Help Needed Puking Fuel!!!!
Fireman
Resident Of Hicktown
ohio
Hey folks me again,
Long story short, leaked 3/4 of a tank in 7 miles. When I saw the leak at a stop sign with truck running, it looked like someone was pour fuel over the motor an letting it stream down to ground. Any ideas? I swear this truck will be the death of me.
02Oilburner
SDD Power Hungry
Raleigh, NC
WOW! :eek: That is not good! Did your truck run funny? Like it was starving for fuel? Is your fuel bowl drain open?:dunno
Fireman
ohio
ran fine, only difference was running late for class im in, it dint warm up for usual amount of time.
Wood County Tx
first thought would be the return fuel thingy on the back of the fuel filter
it has a soft rubber half an oring plug thing in it. its very cheesy and is designed for not alot of pressure....
if i remember right its a 3/4 or 5/8 flare nut
Tbar
SDD STAFF/Moderator
Your going to have to tell us where it was coming from. I have seen bad or improperly fitted fuel bowl orings spray like a fire hose.
Tbar
Fireman
ohio
turnsout, the fuel line going from the connector under the motor to the fuel filter bowl rusted apart. joy! thanks for the help tho everyone
