racor leaking
Tx_Atty
Master Baiter
Fishin'
Anyone with a Racor prefilter - are you having any trouble with leaks? I frequently notice a small wetspot under my filter and fuel all over the canister. A week or two ago I took my filter wrench and managed to tighten it quite a bit curing the problem for a while. Today I noticed a spot again and the canister was covered again. I tried tightening it again but it didnt need it.
Any idea where this could be coming from? All of the hoses and fittings are fine and not the source. :dunno
Tbar
SDD STAFF/Moderator
Is the head unit wet too or just the filter element???
Tbar
Sometimes, Real Tight is not better. Maybe you've Over tightened it and distorted the seal ?
You might try taking it off and inspecting the seal and it's mateing surface for dirt or grit ?
Tx_Atty
Master Baiter
Fishin'
I have been gone all weekend and when I got home there was a puddle underneath. I got under and looked at it appears to be the clear inspection bowl. It doesnt look to be threaded - is it?
The filter element is clean now but the inspection bowl downward is wet.
how do I tighten that?
Tbar
SDD STAFF/Moderator
The clear inspection bowl threads onto the element. I would inspect that oring as well.
Tbar
Tx_Atty
Master Baiter
Fishin'
I take it back. I just looked more closely and it is definitely coming from the element. I backed it off a little and retightened but not as much.
Where locally can I get another element? I dont know that it needs replacing but that leak was a large puddle and I dont want to have a catastrophe happen.
Any ideas on a patch job?
Tbar
SDD STAFF/Moderator
I take it back. I just looked more closely and it is definately coming from the element. I backed it off a little and retightened but not as much.
M & D Distributors
Tbar
Tx_Atty
Master Baiter
Fishin'
still leaking. Can I simply replace the gasket? I still have about 8000 miles to go before I need to change it. For me, that's two more years.
What else can I try? How about silicone caulking around the joint?
Tbar
SDD STAFF/Moderator
Did you pull it off and examine the oring? M & D may sell the oring set separately.
Tbar
Tx_Atty
Master Baiter
Fishin'
no, I didnt have a way to catch any spill. I was also concerned it might start a syphon action and flow all over.
(hey, my 15ooth post!)
