Radiator
6.0PSD777
Mass
The service truck at work just puked its radiator yesterday (2008 F450 6.4L), the parts manager at our Ford dealer said it is common for those. Anyone else have that problem?
ducky1402
member
AZ
I have heard that it is very common, that was one of the major problems with the first year, job 1 trucks in particular.
pubs34
puyallup wa
Couple months ago had my '08 in for it;s 30k check up and when they pressure tested the system found a leak, must have been small, nothing dripping.
08KINGRANCHF250
Smiths, Alabama
Just had my radiator replaced. Took the truck in for a oil change and they said I needed a radiator. I didn't notice it was leaking. Also had to replace a battery (2-1/2 YRS OLD). Also had to replace the overdrive button in the shifter. I love the truck but damn when it breaks.....warranty covered most of it.
Sent from my Droid using Tapatalk
08SuperDiesel
MN/US
yep, mine got replaced. $1100 for me as i was out of warranty. it was puking pretty bad, took about 2 gal in 30 highway miles
bradvan1
lindale tx
I am at 90000 miles and just replaced my SECOND radiator....but dealership has no explanations for why. Anybody got input? I am new to this forum
Sent from my DROIDX using Tapatalk
bradvan1
lindale tx
thanks. Why would I have been through 2 already?
You are supposed to use anti-freeze and DISTILLED water only in the radiator. Adding tap water will allow corrosion to eat the parts on the cooling system, like the radiator. It is only a few gallons to buy for a refill. This applies to adding to the radiator coolant.
KDKT
