Radio Lights Flash
Ndorsey48
Binger, OK
On my '08 super duty, all of the lights on my radio/CD flash rapidly when the headlights come on. When you turn on the interior lights, the flashing stops, and if you click the interior lights off and on several times, you might get lucky and they will stop flashing all together. Any ideas.
WELCOME to SDD.COM ;tu;tu
Sounds like a defective Dimmer/Rheostat control ??
Run it Full bright.. Full dim several times.. check it out. If that doesn't work.. replace it ?
On edit: If yer 08 is still under any Warrenty.. Take it to FORD ??
Burtom
Ohio
Run it Full bright.. Full dim several times.. check it out. If that doesn't work.. click here replace it ?
I think you need to replace them.
castellscl
