JOAT
I Found Nemo!
Just curious if anyone had any ideas. The stock filter bowl has a thermostat where the fuel heater connects in the side of the bowl. The stock one closes around 32* which is fine for petro-diesel. I'm toying with the idea of finding an easy DIY way to raise the temp to 60* or so for homemade B100.
Maybe a snap disc switch on the outside of the bowl and solder the stock one closed? Would be cleaner if there was a way to replace the stock one with a higher temp version.
