Rear Vent Window sticking
dzl_x_4x4
Dzl_X_4x4
Rowlett, Texas
I have a rear vent window that sticks sometimes. It mostly happens it you do not hold down the button for a second or 2 extra after it closes. When it won't open if I use a paid of pliers to twist the hinge where the motor connects to the window, it will work for a couple of weeks. Are there limit adjustments or do I have a dirty contact?
Thanks
patrickc
Ontario, Canada
I would say you either have dirty contacts inside the motor or a dead spot in the motor. I have had problems in the past with moisture getting into my window motors and causing them not to work properly. I just took the motors apart and cleaned them and it cured my problems.
JohnBoyToo
DFW, Tx
Also, try cleaning the gasket surface and inside of the window so there is no "sticksion" between glass and window gasket to cause it to overpower the motor drive...
aklim
Hartford, WI USA
Mine intermittently work. I finally got fed up and changed both motors. They say to clean it with rubbing alcohol and Armor All the gaskets
ForumBlue
CDXX
Southern California
I had mine replaced twice already. My service guy said the motors are notorious for going out. And they have no plans of changing to a more reliable motor. I used graphite powder to free up the last one for a while before I had it replaced.
aklim
Hartford, WI USA
I think we need to help it stretch it's legs now and then. They told me that they haven't had much call for them here.
