Yellowsub1962
supernewbie
sonds like Ford clutch chatter to me. Did you use the friction modifier right from the get go, or di you just add it when you mentioned above that changed the fluid and tried it? If you ran 2 or 3 K without it in "freeway conditions" without it, you likely glazed the clutches. They should clean up by themselves with a couple more services (2-3K miles ea) and using the FORD additive.
I've run Ford 9" posi units for years in various vehicles, and tried many different additives. The Ford additive was always the one that ran the longest and had the least chatter.
Also as a side note, you will feel less "chatter" with more weight as the load absorbs the vbration. It's still there though and needs to be addressed.
PSD
PSD
