regarding egts and egr
silver6o
Tampa, Florida
I have been wanting to delete my egr system for a while to eliminate the possibly of a egr related head gasket issue. Is a small block off plate all thats needed to eliminate the problem for good? Or is there more to it.
I was also wonder what the ideal egt temp is upon shut down, I have a post turbo egt probe and have been told 400 degrees or less is best but Im not sure.
I have an 06 f350 with an sct performance tune and 4" straight pipe.
any help would be appreciated, thanks
PRE Turbo is the way to measure Exhaust temps. Post will not tell you much, as too much energy is lost to the turbo. 400 or less is good to shut down. And there is a little more to the block off plate than you think. Check with Dieselsite (our sponsor) for more on this. Check black Logo, above, on the left of center.
ckamp52
ckamp52
italy,tx and stephenville
yeah there is a lil more to it than a block off plate i got mine from bill at dfuser and u have to put a block off plate where the egr went and on the intake and have to run a new tube and other things to do it right and one for the egr cooler thats why i am doing mine because of the egr cooler leak. i was going to do it myself but got to thinking that if i was going to be tearing that much stuff off to get to what i needed to i might as well do studs while i was at it i havent had any problems(knock on wood) but i'd rather do it all once just in case it does decide to blow the heads now hopefully it will all be fixed next week
silver6o
Tampa, Florida
not sure what i was thinking when i said post turbo my probe is pre turbo installed in the manifold.
thanks for the info, any one else know anything about my egr question?
ckamp52
ckamp52
got my truck back from the shop last friday and it runs like a champ now and hopefully will for a long time now that the egr stuff is gone and studs are in and it runs cooler as well which is good cuz its gettin hot here in texas
strokepower
Stroke=Power
Cook Station, Mo
im looking to do this as well.. everything i've read so far suggests it won't be a bad purchase.... im looking to gather more info.. so if you do this please post what ya think??? good luck
