Removing Dash Bezel on '96 F-250
6LMonster
Wake Forest, NC
Does anyone have some instructions on removing the dash bezel on a 96 F-250? I am installing my DP Tuner F5 and need to pull the bezel....
Thanks!
hheynow
Señor Aceite de Soja
Northern California
Turn the key and put it into 1st gear. This will get the shifter lever out of the way. Remove the two plastic trim pieces on either side of wheel. Remove the screws. Remove the headlight knob (allen key). Gently pull back bezel enough to unhook the two connected wire clips (fuel switch & warning panel array). Install in reverse order.
castellscl
