Ring gear Diameter
Black06
Michigan
2006 FX4 Single with a 3.73. Wondering what what the ring diameter is ?
Buffs F-350
New Jersey U.S.A
If it is a 250 it is a 10.25 a 350 is is 10.50. Same housing different ring gear. But there may be some oddballs out there.
Fire1
Certified Diesel Driver
I believe that older models (90's) had the 10.25. All superduties should be 10.5". They are not different between 250 and 350 except the duallies.
Kleetus
Butler PA
According to the service manuals (2006), the 250 has the 10.25, and the 350 has the 10.5... 450 and 550 change again.
I assume the question is because you're looking to change ratios?
Buffs F-350
New Jersey U.S.A
Most 350 duellys are a dana 80 the 450 is a dana 110 If I remember correctly. My 2002 f 250 superduty had a dana 50 front and a sterling 10.25 rear my current 2006 f 350 has a dana 60 front and sterling 10.50 rear. I beleave all superdutys have a dana 60 front after 2004 but the rears are still mached the same. But as I said there could still be some oddballs out there.Just cheak the axl tags.
