SES light while accelerating
Buddha43
can't afford diesel
Gledale, AZ
I had a strange thing happen today, my truck felt like it was missing and the SES light would come on when I tried to accelerate. The light would go off if I let off the pedal. It did it for a minute or so, then right back to normal. Any ideas?
Buddha43
can't afford diesel
Gledale, AZ
truck is stock. I have done the CPR fuel system from Dieselsite, and the tymar type air filter, but I wouldn't think that would cause the problem.
Buddha43
can't afford diesel
Gledale, AZ
you can only pull the code when the light is on, isn't that correct? The light went out if I stopped accelerating, so unless it happens again and I have a code reader plugged in.....which will never happen btw.
Feel free to spout out some ideas. At least then I have somewhere to start.:burnit
CSIPSD
Bend, OR
You can pull the codes any time... Just plug the reader in and go... I would guess a CPS or a Pedal issue
Buddha43
can't afford diesel
Gledale, AZ
what about fuel filter? if a fuel filter was clogging, would a decreased flow set off a code? Just a thought, I'm gonna get some filters (air & fuel) tommorrow.......
CSIPSD
Bend, OR
Doubtful... I have run with No fuel pressure and still not set any code...
Buddha43
can't afford diesel
Gledale, AZ
well, now the SES light is on all the time now. And the engine still seems to run rough. It is putting out a lot more smoke, but I don't know what color because I was driving it at night. Any ideas? I don't have any.....
roosterdiesel
Earl needs B100
Amarillo,TX
Since the SES light is on, have the codes read to eliminate guessing. It could be a number of things.
