shifting problem with extreme street tune
f100cleveland
When In Doubt,THROTTLE ON
Southern Minnesota
Do you have to let the trans learn a new tune after you install it? The reason I ask is I got 3 tunes from Inovative diesel and have driven around for a couple of days in my normal mode but when I power breaked it just a little to get boost then let off the brake and layed into it I spun threw 3rd gear but then when it got into 4th it sounded like it was against a rev limiter at way over 4 thousand rpms and wouldn't shift till I let off. I tryed a rolling start flooring it and it shifts fine but at 3800 rpms. Haven't tryed the street or tow yet to see how they work but other than that one time shifting I like the xtreme street. Wanted to compare against Dp, Dj, Spartan, Triple Dog, and Edge. Have em all.:dizzy
Yes. but on some tuners you can change the trans psi on shifting and timing.
f100cleveland
Southern Minnesota
So if you drive it hard it will always want to shift hard? It acks really stupid when its cold too. Will it learn shifting for different temps?
Zmann ARGH
AZ
honestly after a few days it should have completed the learn process
I did not like Eric's tunes and pissed away 100$ I went with Matt's a week later and and a happy customer
