shudder????
fordmedic
my 1996 f350 cc duellie shudders at all speeds. Any sugestions, the only mod I have on it is the edge set in tow mode .Thanks in advance Karl
95_stroker said:
Auto or 5 sp?
sorry, auto. im still in the dark ages, hell my computer is water driven its so old i need to figure a way to put my truck particulars under my name.
Auto with a shudder............ check your Under Valve cover harness, you may have a burnt pin or two causing injectors not to fire. Open the oil filler cap, see if you smell burnt electrical.
will do. and don't they sell a kit for that? by the way how do you like your fumoto drain plug ?
Yeah, if I understand correctly you can buy a "kit".
Valve Cover Harness Repair Kits (contains 4 hard shells w/seals, w/o terminals)
(Ford) F7TZ-14489-BA (94-96)
(Ford) F7TZ-14489-AA (97)
(International) 1830829C91 removal tool and Shells w/o pins
(International) 1661875C1 Pins
(International) 2501055C1 Pins with 6" wire
Oops........ forgot to address that question.
I like it well enough. Never have had any problems with it. It makes for a clean oil change. I always keep three empty Delo jugs around from my previous oil change and I drain into them. So for that its nice. But unless your oil is pretty hot it drains a little slow.
thanks , copied if i need it
Just enough time to have a cold one and change the filter. If the oil is cold there is time for two cold ones -popcorn
Leeken
Back
