slow sliding rear window
acjjkamp
Blitz and Harley
Sacramento, Ca
My rear window has realy slowed down to a painfully slow slide, almost to the point of not closing.
is there a lube access behind the panel for the motor and cables? silicone spray? 3-in1 oil?
Thanks
The Ford DVD does not show any lube on the rear slider. It is one cable that is sheived than opens and closes the window. You will gum it up if you add any lube. My guess is that it needs to be cleaned out (the tracks).
acjjkamp
Blitz and Harley
Sacramento, Ca
thanks Dave
I'm going to try some dry silicone spray in the tracks too. see if that helps. I didnt see any dirt in the lower track.
rukirok
