smoking pretty bad
schreckman
Schreck The Tech
Brighton COlorado
man this sounds familiar...check oil level first. If it is low, fill it. Check power...next run a external fuel line from rear of pump to small fuel tank, run it. Is it better? I had all kinds of crud in my pick up screens. Once that was clean my power came back. As for the smoke??? May want to check the injector bolt torque. I messed mine up the first time as well and started getting pressure into the cooling system. It sucks to pull the covers again but that is the way it goes.
bigblak250
florida
would starving for fuel cause it to smoke? i never had the problem before i messed with the injectors...oh yea, and 2 of the injectors had what looked like rust on them when i had 'em out, what would cause that?
turbo is good, now its running really bad, smoking, skipping worse, losing power but if i hold it to the floor when it gets over 2500rpm it stops smoking and takes off, any slower it just feels like its gunna stall
air in the fuel rails..
drive it like you stole it to purge it out.
