Sound dampening
sagebel
Stock? Pfft!
Albuquerque, NM
Anyone done it? I am looking for suggestions that won't break the bank. (Door seal mod complete.)
Scott
irish4x4
Mayor of Margaritaville
Reno, Nevada
Dynamat inside door helps quite a bit too. Four door gets a little pricey but check ebay and deals pop up once in a while.
i used hush mat...less prep work & cheaper than dynamat.
I did all my doors, rear wall & roof...the doors made the
biggest diff !
I did the roof to help reduce the heat more than anything.
c'mon over, help me pull all the seats and we can do the floor
on mine & ill help you apply the stuff to your truck in favor !
sagebel
Stock? Pfft!
Albuquerque, NM
I am going with B-Quiet. I am planning on doing the floor, roof, doors, back of cab, and as much as the firewall as I can get. Bush: It be easier if you came here. I have already removed everything out of the interior with the exception of the dash and headliner (next weekend's project). It might be a long drive to Texas sitting on a 5 gallon bucket.
Scott
use some additional foam or carpet padding on the floor...i hear it helps too.
georgetown texas
Thinkin bout buyin the hushmat and having it installed when i have this company install my cab lights. Since the headliner will already be down it should be the easiest.
platinum01
Willis, TX
Bush give me a call when you are going to do this, I need a reason to buy some HushMat and install it on the back wall and the roof. Need something to quite down the exhaust.
