Help Needed Speedometer failure
Shread Head Fred
Oregon City, Oregon
Hello All,
I have a '99 SD 7.3 F-250. I was returning from July 4th weekend when I noticed that my ABS light came on, and my cruise control was not working, then my speedo was not working. I called my local repair shop and of coarse he said bring it in. I then checked the fuses which looked just fine.
Has anyone had a similar problem. Can you gives me any ideas, direction?
Thanks,
Fred
keanoknick
Big Stroker
Cowtown TEXAS
:w4
My guess would be the speed sensor in the rear differential, is bad, or needs cleaning.
If you post this in the General Superduty section, you'll likely get more replies.
:w4
X2
It's called: Vehicle Speed Sensor (VSS) 25 dollar part ? Just replace it.
10mm bolt, hold down clamp, 2 pin plug.. 15 minute fix.
Parts'r cheaper in Estacada
hawkdriver
Lake Martin Alabama
My speedo is stuck under the peg after a dual battery failure a few days ago (see 911 thread). I'm assuming my VSS is still working as my cruise works just fine. Any suggestions??
