Staring to get a rough idle
ejpowerstroke97
Breaux Bridge, Louisiana
I noticed this about 2 weeks ago. Truck runs fine just just when sitting at a stop light or in park idle has a tendency to surge a little. Not all of the time though but it does seem like it is getting more frequent. Also when I change my fuel filter last weekend i noticed that there is some gunk build up at the bottom of the fuel filter housing. Do I need to remove the housing to cleani it? If so is fairly easy to do? Thanks guys. Any info greatly appreciated.
If you are getting a surge at idle you might be starting to have o-ring leakage on the IPR valve. As for the gunk in the bottom of your fuel bowl, drain the bowl and use a rag or towel to swab out the cannister.
action4478
Muskegon Mi
It should be just below the filter resevoir. There are two red (i I think) wires going to it. I will have a large 1'-1 1/4nut on it . Injection Pressure Regulator
ejpowerstroke97 said:
What and where is the IPR Valve. I am still not familiar with all of these abbreviations. Some one needs to make a chart.
Look here for a procedure on cleaning and re- oringing the valve.
Linky Dinky:sweet
hheynow
Señor Aceite de Soja
Northern California
Wouldn't that throw a code (1211, 1212, 1280, 1281, 1282, 1283 or 1284)?
94f450sd
certified nutjob
plymouth,ma
not always.it may leak but it may also still hold enough pressure to keep it within specs.there is a certain margin of error that the pcm allows.
also the solenoid on the IPR may be loose and wiggleing around.
