Steering Box Leak
clem
N.E.Ohio
Any one know if I change the bottom oil seal of the steering box by removing the pitman arm and pulling it out from the bottom. Thanks
I would think not. The shaft will get in the way of "pulling" it out. You will have to remove the shaft and then pound it out.
JimmyDee
God Bless America
Western Michigan
I changed on my Grand Marc and just pulled the Pitman arm. If you are lucky, after the arm is pulled, put an oil pan under the seal and start the truck while turning the steering wheel at the same time, you have about a 80%-90% chance of blowing the seal out with oil pressure. It was about a 15 min job for me because the trick of allowing the hydraulic pressure remove the seal worked for me. The truck may have a different gear box and may or may not work.
Jim
clem
N.E.Ohio
JD I think i"ll give that a shot. If that doesn't work I'll try digging it out with a pick and a screwdriver. If that doesn't work I may have to resort to disassembly method,thanks
JimmyDee
God Bless America
Western Michigan
The guy that told me that trick also loaned me a couple of picks and said it was about an hour job to get them out that way. Don't know if he was pulling my leg or not but the pressure way worked slick.
Let us know how it worked.
Jim
clem
N.E.Ohio
I haven't been able to get to it yet. Hope this weekend
