hheynow
Señor Aceite de Soja
Will tackle that leak once the red stuff quits hitting the floor.
Red stuff?
CAT Extended Life Coolant is Red..Red stuff?
Red stuff?Coolant is green, oil is amber to black. Are we talking about ATF or blood?
is the fuel actively leaking? or could it just be residual from the work previously performed?
if you haven't already changed out your thermostat, mine was just leaking from there last week and it turned out that when i put the housing back on after installing the water pump, I overtightened the bolts and warped the bottom of the housing a little bit. hit 'em back out with a hammer and all is good.
Worst case scenario is a new fuel pump.
I hate leaks![]()
