Swapping 6.4 for a 6.0 can it be done?
Discussion in '6.4L PowerStroke Engine & Drivetrain' started by Heavy Hauler, Feb 3, 2016.
  1. Heavy Hauler
    Heavy Hauler SDD Junior Member
    Feb 3, 2016
    Southaven, MS
    Can anyone tell me if you can swap out a 6.4 for a '03 6.0 in a 2008 F-series? Also will the '03 6.0 mount up to the automatic from the 6.4? the 6.0 currently is backed by a 6spd
  2. WD40
    WD40 Full Access Member
    Why would you want to do this, you must have a 2008 truck and if you put a older engine in it you will make the truck worth a lot less.
  3. carbonation
    carbonation SDD Junior Member
    46
    14
    Mar 17, 2018
    Midwest
    You can do anything with enough time, money and resources.
    Swapping a 6.4 for 6.0 is just trading one set of problems for another, but at least the 6.0 problems can be addressed.
    Much easier to get 6.0 truck to start with.
    If swapping, why not consider a Cummins swap?
  4. 79jasper
    79jasper Full Access Member
    30
    228
    24
    Aug 9, 2015
    El Paso, TX
    I read it as taking out the 6.4, in favor of a 6.0.
    Likely a lot of wiring harness to be swapped as well.
    Sent from my SM-G892A using Tapatalk
Share This Page
