Hoss 350
My GSP, Dutch
I would like to try and reduce the sway that I experience with my 94 Lance 480 9.5 foot camper on my F-350 SRW. The truck does not have progressive overloads (which would probably help a lot), nor does it have a rear sway bar (which would probably help a lot).
I have developed a couple of options, which do you guys think is best?
1.) Aftermarket Hellwig rear sway bar only - $250
2.) Air Bags - $350
3.) Prgressive overload springs - $?
4.) Combinations of any of the above for maximum benefit…
I have an acquaintance that says that his airbags made the sway worse, that they were bouncy like afootball. But I would belive that this individual would be dumb enough to not run independent lines to them, so they were probably transferring pressures back and forth.
I like progressive overloads because they require no thought 9you don’t have to add or release air pressure) and do not effect ride at all when empty.
I don’t know how much difference the sway bar makes, but presumeably, a big one, since my buddy has one and does not experience sway like I do. So, I am leaning towards progressive overloads and a sway bar.
Any input or other ideas?
2.) Air Bags - $350
