t-case help?????
the obs t-case will bolt up to the 4r100 the bolt patterns are the same the variables will come into play are the outputs so you can use your driveshafts. The other question will be the electronic shift shenanigans if you have them.
The SD transfer case is a higher power rated model so if you have access to the OBS case cheap to get you on the road then it is an option if the shafts will connect.
bigblack250
Branford, fl
anyone know what front drive shafts interchange? like if one out of a gas truck or a 6.0 truck is the same legnth?
Bigblack250.
I have a buddy over in Mayo he's a big truck nut, I give him a call and see if he has one sitting around. He work of the state penn so it my take a few days for me to get him.
bigblack250
Branford, fl
ok cool, thanks, i started to put my new t-case in today and noticed that it busted my trans around the bell housing, i have a good spare case so i guess tommorrow i'll start swapping the guts out =(
Milly333
