Tail light/directional light wiring
`08 Blue Crew
Somewhere in the lower 48
Can someone tell me the color coding for the let and right tail light assembly. Particularly interest in the directional and ground wiring. Or at least direct me to a wiring diagram for these assemblies.
`08 Blue Crew
What I am looking for is this. When I pull the tail light assembly from the truck, the large bulb (tail light, brake light and directional) has three wires running to it. I assume each wire is for 1 of the three functions. I am trying to find out which wire controls what and for each side (L and R).
I am replacing the incandescent bulbs with LED bulbs. I need to put a load resistor in the line, but I don't know which color wire is for the directional on each side.
pychokenny
Parkin, AR
go to autozone and get a heavy duty flasher and your leds will work fine i did this on my 94 chevy, 2001 dodge and my 2005 f250 just make sure you have the rite bulbs sould be a 3157
Or.. an [Electronic] flasher.... that replaces the OEM [Thermally] operated one.
