JRJ04
Well I swear to God, everytime i touch my truck...I never get done what I want becuase I always end up &@!@$% something up in the process!!!
Well earlier this evening, I decided to remove the EBPV tube and clean it out per the instructions on Guzzles homepage. Took the sensor out, all was well and then moved on to detaching the tube on the top of the motor. The instructions require the use of a crow's foot wrench due to the lack to room you've got to work with. So, I had the crow foot attached to an extension and socket and then another wrench in there to serve as a back up. you get the idea...
well the nut wasnt moving and so i decided to not force it and pull everything out and hit it with some penetrating oil and let it sit. Well I'll be darned if the crows foot didnt fall off the ratchet when i was pulling it out. Now for the zinger......the crows foot fell inside the "wheel" on the engine that the fan is attached. I spent hours trying to fish the thing out of there and you cant get it out from the bottom because there isnt enough clearance around it, so it has to come out from the top. but of course...gravity is working against me here and i cant pull it up.
Now, without further ado, my question. The engine runs fine with the thing in there. it doesnt hang anything up, the belt turns fine, fan turns well...everything is cool. Does this thing need to come out of there? What kind of risks do I take leaving it in there and living with the occassional rattle? Could it cause the "wheel" to get out of balance? I just know its gonna take some work to get that thing out of there because the fan is going to have to come off and god knows what else. Needless to say its going to my mechanic if any of that has to happen.
Sorry for the long post....your thoughts please?!?!
