I got one other unidentifiable sound I can't figure out where it's coming from as of right now. It's a slight chattering "squeak-squeak-squeak-squeak" - sounds like metal touching something that's spinning, this is from a dead stop or close to it up until about 8-10 MPH then ceases to make noise. Only happens driving foward.
Ideas? Think it could be a caliper shim touching the rotor? Anything in the driveline?
Sounds seems to be originating from the drivers side, can't tell but it might be coming from the rear, or atleast the sound is traveling from the front to the rear. Would one seized or about to be seized bearing cap on a u-joint make that sound?
