Help Needed tire help
mr0195
crestwood, ky
I have recently inheritated a 07 f-250 crew cab 4x4. I have put a 3 inch lift on it and want to get about 2 inches higher with 35s. It currently has 31s. What i am wanting to know if anybody knows if i put 35s on it, what size rims can i put on it without having rubbing issues with 35s. I dont want to install a higher lift. if i can put 35s on it, it will give me the clearance i need to climb this hill. i want to use the bf goodrich t/a ko's. can anybody help?
Mike
I had 16.5 X 12 rims with 12.5x 35" and had to cut some metal behind the plastic tire well. Down by your feet. Then had to put a 1" spacer in the front bumper to move it forward thas all.
bears4x4
grease monkey
katy texas
i have my truck with a leveling kit on the front with 35" tires on 18's i had to trim a 3"x3" piece out of my front part of the fenderwells to alow for full turn. looks good in the pic :) btw (my truck is sitting lower in the rear in the pic cuz i had lot of weight in it that day )
HeavyAssault
King William, VA
2005-2007 trucks require 17" wheel or bigger to clear the calipers correctly. For width I'd stay under 10" to prevent other issues while driving.
