tire Q for a dually
XTrmXJ
NACHHOOOOOOO!!!!
Hampton Va
Im currently running 235/85/16 on my dually,, There is a guy locally selling 4-265 75 r16 Pirelli Scorpians with full tread for cheap.. My consern is for one will they fit on the rear with out touching themselves and how much of a difference is an 85 tire to a 75
Patrick Feeley
Tehachapi, CA
I would bet the 265's would rub the sidewalls together. My 235's don't have that much clearance, especially when loaded. The tires are probably within 0.1 inch in diameter (265/75 vs 235/85). Cheers!
DozerDoug
Fairbanks Alaska
Well it is hard to tell without actually measuring them. With the metric measuring systom, the first number is how many millimeters wide the tire is. The second number is the aspect ratio, I/E 85= 85% of the width is the hight of the sidewall from the rim to the tread. 75=75% and so on. So a 265/75/16 tire is about the same diameter as a 235/85/16 tire but just over an inch wider.
police stroker
Dallas, Texas
I have 265/85/16 on my truck and have to use a small spacer to keep a good amount of clerance between the rears. Good luck all you need is like a 1/4" spacer or smaller not very much.
Patrick Feeley
Tehachapi, CA
Caution!!!: You need to be very careful if trying to use a spacer on an OBS truck as our wheels are hub-centric and not lug-centric. There will be no shoulder left on the hub if a spacer is used between the wheels. Cheers!
XTrmXJ
NACHHOOOOOOO!!!!
Hampton Va
Thanks guys for the response, now knowing that they will be smashed together I wont get them...
