Feb 24, 2008 #1 S Stroke Full Access Member Joined Nov 17, 2007 Messages 105 Reaction score 0 Location Salinas,California What do I need to do to fit 33X13x18 toyo tires on a 97 f250?
Feb 24, 2008 #2 Crumm Fordoholic Joined Apr 17, 2005 Messages 5,704 Reaction score 5 Location Fairbanks, Alaska Shimming the front bumper out a little should be all it takes. They may rub on the springs a little when you turn to full lock.
Feb 24, 2008 #3 S Stroke Full Access Member Joined Nov 17, 2007 Messages 105 Reaction score 0 Location Salinas,California do I need to lift the truck?
Feb 24, 2008 #4 Crumm Fordoholic Joined Apr 17, 2005 Messages 5,704 Reaction score 5 Location Fairbanks, Alaska No, just shim the front bumper out a little.
Feb 24, 2008 #5 S Stroke Full Access Member Joined Nov 17, 2007 Messages 105 Reaction score 0 Location Salinas,California could I do the RS on a f250?
Feb 24, 2008 #6 Crumm Fordoholic Joined Apr 17, 2005 Messages 5,704 Reaction score 5 Location Fairbanks, Alaska Yes you can. You can build your own or purchase one from Sky Manufacturing. Off Road Unlimited only makes them for the F350.
Feb 24, 2008 #7 S Stroke Full Access Member Joined Nov 17, 2007 Messages 105 Reaction score 0 Location Salinas,California do I have to do anything to the frame to make it work? In Sky's site it say that I have to buy the drop brackets. Where could I buy them.
Feb 24, 2008 #8 Crumm Fordoholic Joined Apr 17, 2005 Messages 5,704 Reaction score 5 Location Fairbanks, Alaska Most lift manufacturers make the drop brackets. If you plan on keeping the truck for long converting to a D60 would be better than installing the drop brackets.
Feb 24, 2008 #9 S Stroke Full Access Member Joined Nov 17, 2007 Messages 105 Reaction score 0 Location Salinas,California you know how much it cost?
Feb 24, 2008 #10 Crumm Fordoholic Joined Apr 17, 2005 Messages 5,704 Reaction score 5 Location Fairbanks, Alaska How much what cost? D60, RSK or Drop brackets? D60 is going to run $900-$1,800 RSK is $300 for Sky Manufacturing Drop Brackets are $150
