Tonights Project
I finally got started on my boat recovery winch project last night. I thought I would share a picture or six of my progress.
Before
Fairlead I modified. Remember my "can billet aluminum be bent" thread? Answer is yes it can :D
The hole I cut:eek: Hope it don't leak
Fairlead, hook and line installed
The winch I am going to mount
The hole it is going in
Hope to finish up this weekend. Time for bed now... good night
Tbar
SDD STAFF/Moderator
Looks good but...................does it have an ice breaker on it too??? :D
Tbar
Yep if you look down a little lower on the front you will see the sharp angle iron welded the full length. They will cut through thin ice like butter. :D
I also installed a new steering wheel while I was at it
old
new
The rivers are starting to go out and I am getting gin the mood :sweet
Wood County Tx
this might seem dumb,
but why do you have a winch on the boat? is it for crossing mud puddles or pulling logs off the "river trail"
What is it they say "a picture is worth a thousand words"? We run very shallow water on the interior rivers of Alaska and sometimes it gets a little too shallow. I can run in about 2" on step but still get hung up from time to time. If you look at the front you will see a Rope-a-long hooked up. I am thinking that with a electric winch the "recovery" will be much quicker.
Phantom even makes a wheel kit for there SportJon for when the going gets tough. Too bad the rest of the boat is a piece of junk though.
