TPMS Problem 09 F350
nhff2
North Haledon, NJ
just put new wheels and tires on my truck. I cant get the TPMS to reset. Im thinking that its not resetting because im only running 45 psi in the new tires and the factory pressures are much higher. any advice as to what I can do to get the system to reset??
Your air pressure is too low. Run 50 psi at least. I run 60 psi in, all tires, all of the time.
nhff2
North Haledon, NJ
yes i am using aftermarket wheels, and yes I did have the sensors installed on the new wheels. I have no problems at all with "Training" the truck with the new sensors, everything seems to be ok. i tried driving the truck for a few minutes like the manual says but the display still shows low tire pressure every time i start the engine
nhff2
North Haledon, NJ
Thanks DaveBen, im trying to keep the pressures low, the max on these tires are only 65....
You will do more damage to the tires by under-inflating them, than you could do by running them at the rated pressures. But it is YOUR truck.
nhff2
North Haledon, NJ
hey any suggestions are better than where im at right now, i will give it a try and see what happens
IHC Power
STOCK STROKE
Walpole Mass
Tpms
Just a fun fact for you. When the 2008 trucks came out i found some valuable information about the TPMS on FMC Dealer. On most 350's the tire pressures are different from front to rear and the 250's are usaully the same. So Ford says "after tire rotations the TPMS must be recalibrated and pressures adjusted to match" The door sticker on the truck has the specs, set to that and recalibrate the system, see how that treats you.
there are two different TPMS sensors for Ford pickups.
A high pressure one (green - trips at 55 psi) and a low pressure one (blue - trips at 27psi)
these are held to a cradle by a couple of clips, the cradle is banded to the wheel 180* opposite the valve stem..
When you're using the procedure in the Owner's Manual, all you are doing is putting the system in "learn" mode. You need the electronic transmitter tool to actually re-train the sensor.
I deal with this stuff all day, every day.
run the tires up to doorpost pressure, take it to the tire shop and pony up the five bucks to have it reset.
Fine69
Cranberry Twp,PA
The trucks come with the tool.
