TexasA&M
Does anyone know how the stock trailer wiring is set up? From the 7 pin connector, is there a plug somewhere by the back bumper, or is it just wires running up to the fuse box?
The reason I ask is because the previous owner of the truck tapped into a bunch of the wires at the 7way to put in other plugs. I think this might be causing me a ground issue (and I never use the other plugs), so I want to replace the 7way, and the wiring. I'm hoping that it's a separate harness that has a plug under the truck that taps into the main harness, similar to the 'T' connectors that they sell for other vehicles that let you add trailer wires without splicing into the vehicles wires.
This isn't exactly what I'm talking about, but it should give you an idea -
Ford Trailer Wiring Kits - 2002-2004 Ford F250 / F350 Super Duty - Trailer Wiring Kit
Let me know what you guys know. If it works like I hope it does, I'm going to call up some junk yards and look for the harness, and a new rear bumper.
Thanks,
- Steve
Thanks,
- Steve
