Vinni
I didn't do it
Fellow S/D owners,
I have recently put a 12" lift on my 2K XcursI. I am contemplating running a set of G rated 46" tires with 20" wheels. Understandedly, running these big tires will put quite a strain on the transmission behind the 7.3 diesel.
My question for ya'll is what steps can I take to effectively protect my tranny? Would the SONNEX kit be an investment toward my goal?
Additionally, if I were to change out the gears in my diffs, would it be required for me to change out the gearing in both ends if I am in 2wd 99.9% of the time? Would you happen to have a suggestion as to what gear ratio I should be running with the 46" tires to attempt to return the truck to a stock performance level?
TIA
TIA
