trackspeeder
Stone Crusher
AMSOIL, I did this yesterday!
(New filter, Sonnax modulator kit, B&M drain plug and 5 gals of Amsoil).
Anyone know what the transfer capacity is? Still need to do this.
I think it was a little over two quarts.
Correct.Synthetic is no more slippery then plain old Mercon or Mercon V.![]()
Ok finally got pan off today. Had been to wet to get to it. Magnet has some filing on it, no big pieces.
Here's pic pan off.
The stuff on side is from the outer case, fell in while getting it out.
Rag after wiping
Nothing big, but I am not sure if this is to much or about normal. I have put 50k + on this truck since bought. Fluid smells fine, a little dark, here is a pic of it on a white rag.
Overall looks good????
Have one other question, new filter has an orange gasket(??) around filter input. One I removed did not or didn't come off with it. Should I look around, I pulled the new one back off and the orange gasket stayed, should I pry it out and see if one is in there from the old filter
And do yall suggest flushing it or not?
or did I miss a step in flushing? I pulled the article from Wiki and also one from a post ( both same with little diff like drain TC) I refilled the trans through dipstick with 7 qt of ATF, then cranked. I don't see this going the way it is written, so did I miss something or do I need to plug the trans side of cooling lines?
Ok, tranny filter changed. Took rear coolant line off attached hose to line. Crank truck, get some fluid in hose, but I have fluid running out of trans while running and none going into hose. Did I screw up something?or did I miss a step in flushing? I pulled the article from Wiki and also one from a post ( both same with little diff like drain TC) I refilled the trans through dipstick with 7 qt of ATF, then cranked. I don't see this going the way it is written, so did I miss something or do I need to plug the trans side of cooling lines?
I mean this reads to be real easy, do I have wrong line? It is the furtherest line, last line on Pass side of truck just in front of end of tranny? I have been over the procedure many many times. I am a novice with Auto trannys, but I am losing it here because it should be simple.
