Transmission Temp Question??
zr1pete
Florida
What would be a normal trans temp on our trucks, everyday sort of drive not pulling or hauling anything. I thought I read somewhere it might be 100* plus the ambiet temp, Is that about right? Anyone with an aftermarket gauge know?
Wood County Tx
thats pretty good geuss
we run with the fiver in tow and outside temps in the low 90's it was 165-185 at 70 ish
flat ground she normally hangs at 165 ish
empty and cold like latley and it never gets off 100 ;)
thats a good rule of thumb BUT...on a 100* day you shouldnt see 200*
temps.
Im lucky if i top 150 for the most part...towing 6-8k lbs ive seen no
more than about 165*
patrickc
Ontario, Canada
I normally run about 110* empty and 125* towing 8000lbs. It's very rare that my temps ever go over 150* even in the summer heat. My transmission rebuilder told me to make sure I keep mine under 180* if I want it to last any length of time.
John Boucher
Florida
Mine sits at 150 or less unless I'm towing the 5th wheel, if its hot outside it may get to 165
