truck died while driving
john67
niagara falls ny
have a 1999 ford f350 with 7.3 about 156,000 on it and was driving on thurway and was going around curve and truck died.check fuel and getting to bowl,the wait to start light comes on then goes off when cranking the rpm only get 300 rpm and no oil pressure on gague check fuses and all good.thereis no smoke comming out exhaust when turning over was thinking cps unit?? any other help will try thank you john
There is another, current Post, addressing the same symptoms. Yours also sounds like a CPS going bad.
If you haven't replaced the OEM black one.. replace it with "Ford recall" Grey one..
towed home got two month old battery with new post on them know battery mean lot of it
Hmmmm :dizzy Yul need 2 GOOD batteries of the Same type. Or am I not understanding what you mean ?
got both battery at same time new,2 months ago if trucks was running dont alt kick in too
Yes.. You should see 14.5+ volts, but not more than 15v, when the engine is Running. Engine off, you should see 13+ volts. If you've been cranking it.. you may need to Charge the batteries ?
