Truck dies Randomly
fastford
Redmond/Oregon
Truck started to just die recently. Off like a light switch. No codes. No hiccups. No lights. No warning. (I have replaced the CPS Once..a while ago)
1st time I was towing my TT coming down a grade. Off. Would not start back up. Crank fine. Wouldnt even bark. About an hour goes by and it restarted ran fine and drove it home 2hrs.
Took it into my local diesel performance shop (Performance Authority...great bunch of guys) they checked it all out. No codes other than some Cam code they said was probably from cranking on it so much. They checked all my connections..IIPR? everything looked ok.
2nd time same thing...only this time not towing...about 45 minutes into a drive and like a light switch. Off. Started back up after about 30 minutes, made it another mile and off again...this time for about an hour. Started back up and made it home....Starting to seem like heat is causing it...cools off and fires up again.
Starting to think maybe my chip is going bad...so i pull it out....let it idle for about 40 minutes and then go for a drive...died in about 5 miles...crank crank crank...nothing...let it sit 45 minutes and started up and made it another mile...
towed it home...it started right up...Replaced the CPS tonight...let it idle about 20 minutes was getting ready to test drive and it died in the driveway....WTF!!!
Someone that has any ideas please help? More than frustrated now.
Erik
Hi Erik and :welcome3. What year and model of truck are you referring to? Sounds like a 7.3 liter motor. We will need a few more facts, like mileage of the truck, modifications to the truck.
Dave :)
fastford
Redmond/Oregon
Sorry. Looks like it didnt save my signature....
2002 7.3L F350 CC SWB, 100K miles, DP Tuner F5 with PHP Tunes, WW, AFE Stage II, AIH Delete, MBRP Duals, BTS Valve Body, Diesel Site PSD Wastegate Controller.....
Remove the tuner from the equation and see if it still stalls. Tuners cause problems, in general.
Dave :)
fastford
Redmond/Oregon
I removed the tuner and tried before I just replaced the CPS sensor. Currently there is no tuner and a new CPS. Still same symptoms.
even replacement CPS's do fail..
the cam related code makes me think this..
