truck wont start in park
bears4x4
grease monkey
katy texas
truck wont start while the shifter is in park sometimes, i have to shift it to neutral , im guessing it has to do with a linkage- shifter adjustment , anybody done this before.??
check the arm on the column where the cable connects.. some older trucks & vans the screws like to loosen up..
may have a range switch/park-neutral sensor/neutral safety switch starting to take a poopie...
ckelly99PS
fostoria, Ohio
Were you able to fix it and what was the issue....I have the same deal going on with my truck. Thanks, Chris
ckelly99PS
fostoria, Ohio
Is the neutral safety switch the black thing on the drivers side of the tranny with a slider rod attached to a half rotating lever ? Who has these for a reasonable price, or is that an oxymoron when buying transmission parts ?
ckelly99PS
fostoria, Ohio
Another symptom I have is that the truck will not physically go into park no matter how much I wiggle the auto gear shift.
bears4x4
grease monkey
katy texas
my problem was my actuall shifter arm was loose, i just replaced my shifter arm and it worked perfect afterwards
ckelly99PS
fostoria, Ohio
Replaced the shift tube and shaft along with new plastic bushings on top of the steering column which fixed everything.
