turbo breakdown pics.....
geonc
my other 4X4
NECKVILLE NC
I'm in the middle of re-building my turbo-stock Garret TP38.
Have it 99 percent done except for ...and this may just be in my mind :eek:
but at the hot side where the turbine wheel backs up to the center section appears to be another section that should come off?
FYI- when I removed the shaft , the bushings look no different than the new ones:thumbs and the only evidence of oil found was a small amout carbonized on the housing in question....the source---I believe---of my oil consumption.
Am I crazy or just looking for something that isn't there?
:confused: do I just lube up the turbine piston ring and send it home and assemble the turbo?
see pics for 2 mystery seals:dunno
I already have a square cut seal for the center section to compressor side and the one in the pic is smaller in dia but thicker in cross section......
Oh yea....pic of new pre-turbo pyro location:sweet
Got all hardware loaded with never sieze....just need to get this stinkin' turbo on to snug it all up and stuff that engine back in:burnit
Geo,
Ive got a thread here somewhere from when I rebuilt my turbo. I cant access my pics right now from this puter but I dont recognize that funky shaped seal?
My brass bushings looked good also when I tore it down, all I had was the carbonized burnt oil too. I had very negligable end play and once rebuilt it spun smoothly.
geonc
my other 4X4
NECKVILLE NC
:thanks Mike
Just gonna lube her up and seat that turbine piston ring and together she goes....
geonc
my other 4X4
NECKVILLE NC
:thanks Mike
I'm still courious as to what that turbine ring rides on in that hsg:confused: :dunno
