Turbo is Coming Out...What Else Should I Replace?
lone_star_dsl
Falcon, CO
It appears as though I have lost a seal somewhere in, on or around my turbo. As it sits, I have oil residue on the turbo, on the hood above the turbo, in the valley and on my driveway.
So, while I have the turbo out, what else should I be looking at replacing? Basically, if it requires removal of the turbo to fix, I want to do it.
Thanks
just what you were going to do already.. pedestal o-rings
RSG
Savoy IL
...and also, if you haven't already, consider upgraded boots for the turbo and intercooler side of the tubes. Clean out the oil and seal it up?
Times 2.... and upgraded intake plenum boots too ?
While you've got everthing removed.. might be a good opertunity to Clean everything on the top-side of the engine ??
Frankenstien
Frankestien
South Prairie Wa.
.... new exhaust O rings... I recommend using the Chev Small block ones, they are a little beefier. just to help when it come to look up via application, just state a 1969 chev pick up 350 small block...
